Hey guys. I just got my valve cover powder coated and I figured that since I have a 2000 GT-S I might as well swap the lift bolts at the same time. I just did the swap and well when i loosened the old ones they were semi hand tight. So when I install the new bolts the top one tightens hand tight without a problem but the bottom one keep on turning? I am afraid I stripped something. I tried to pull on the bolt to see if its tight and it doens't come out so I assume that its tight? Anyone run into this problem or can give me advice? I am afraid that something might go wrong when I go back to driving the car. My buddy says I'm in danger of throwing a rod? Any help would be most helpful. Thanks.
