I've never actually removed mine so I don't know but if you open your glovebox and remove the two plastic screws you can pull out the glovebox and you can see the amp.
you should be able to reach it by just dropping the glove box, two larger plastic "bolts " for lack of better term, you twist them until the pull out then squeeze the sides of the glvoe box in a little bit allowing the rubber stops to clear the sides, then just unplug it and remove the two mounting bots, should be a 10 mm i beleive
