1 - 14 of 14 Posts
how loud is the stock gts valve train supposed to be cause myn seems a little noisey and ive never miss-shifted or went over on an oil change!!! any ideas?
Mine chatters a little. It was louder until I changed to synthetic oil but ti's still loud compared to 3 years ago
Just call me GnG
Are you hearing this from the inside of your car? where exactly is the sound coming from? I had the same problem awhile back. The noise came from my glove compartment. Turns out that the cabin filter wasnt securely in... and missing the filter itself.
Ha!
I went to change mine some time back and it was gone too. Who is stealing these filters?
For some reason they don't come with the cabin filters even though there's a space, guess toyota wanted to save a couple bucks.
weight reduction ;)
yes the celica does not come with a filter, most people go out to home depot a pick up some 3M filtering media and cut it to shape.
Originally posted by All_MTR_GTS
weight reduction ;)
Ha! My celica is PHAT.
The driver is FAT.
:chuckles:
Beer is making me feel better. You're all right Matt.
The driver is FAT.
:chuckles:
hehe im qouting u on this one so its not deleted!!!
Red01GTS said:
Damn, I'm a poet and didn't even know it.
I'll cut you some slack and agree to this fact but I think maybe you should make a better rhyme next time ;)
Just call me GnG
Red01GTS said:
Ha!
I'm guessing the Toyota Dealership. it was fine up until i brought my car in for a 60k at the beginning of this year. Either that, or it got sucked into vents.
Sounds like the clearances on your valves are a bit too high. If I remember right the GT-S uses a rocker arm so adjusting em shouldn't be too hard, probably have to mess around with some sort of adjustment screw.
Negatory.........each valve has its own shim........you have to get the right sized shims from toyota,
1 - 14 of 14 Posts
