1 - 2 of 2 Posts
I just put a new lower ball joint on the left front (Autozone). The last one only made it a few months. This one made it two days. They are blowing the grease out of them. It is only the left side. Is it possibly because of the 'cheap' joint or should I look for something else? I just lowered the car 1.5" and had it aligned right before this happened this time. The last one was stock height. If I change this, will I need a new alignment?
Most places will only adjust your toe. Im trying to diagnose my problem too. If you remove your tie rod an allignment is recommended. Stock cambers can only be adjusted so much. Didnt touch allignment after my drop. Drives better for some reason. Did you remove the control arms?
1 - 2 of 2 Posts
