1 - 20 of 21 Posts
I want to lower my car only for the reason I don't want my car to look like a rake, would that be possible?
<a href="http://imgur.com/hG57auW"><img src="http://i.imgur.com/hG57auW.jpg" title="Hosted by imgur.com" /></a>
<a href="http://imgur.com/nbyawqu"><img src="http://i.imgur.com/nbyawqu.jpg" title="Hosted by imgur.com"/></a>
<a href="http://imgur.com/DI7nHLe"><img src="http://i.imgur.com/DI7nHLe.jpg" title="Hosted by imgur.com"/></a>
<a href="http://imgur.com/Dxyn7J5"><img src="http://i.imgur.com/Dxyn7J5.jpg" title="Hosted by imgur.com"/></a>
not sure what you mean by rake but damn those are big wheels for stock body. id go with 17's
if you drop both ends itll be fine with no "rake"
Spanning Tree Storm
buy coilovers and you will be fine
Those tires have a high profile. Other than that, the 'rake' I think you're referring to is the OEM setup. You'll need coils to counter it. Remember that your headlights will need re-alignment when you're finished if you change that 'rake'.
Don't kneejerk a coilover purchase. Do your homework. And realize any coilovers change your ride quality by quite a bit.
Treeme100 whoever said coilovers give you bad quality. Wrong. I had stock oem suspension was shit. Than went with Eibach pro kit fucking terrible and now I have Ksport Kontrol coilovers. Best decision I've made to date. With coilovers especially with Ksport you can adjust dampening settings for ride quality. 7kg front / 9kg rear perfect for all road conditions. I live in Alberta. Truck heaven. Although my Celica slammed has no rough driving abilities.
Your other option is Ksport air ride pro edition, sure expensive but you can raise lower a moment notice.
Hope this helps ;) just my (2) cents bra.
Sorry, been gone a while. The ride changes completely. She'll be quite stiff so get something you can adjust. I live where the roads are complete crap almost year-round - cracks, potholes, etc. The difference is shocking. But when you get on some smooth curves there's no comparison.
I have the Megan EZ Streen coils and will eventually upgrade to full race coils but for $700 they have a decent ride on maxed damper and loaded springs. Like they mentioned above, KSports are what I had on my last Celica and they were almost perfect but 900 bucks.
What about the Tein SS coilovers? How do those compare to everything else mentioned? If I'm not mistaken that also have a EDFC unit available so you can adjust the dampening on the fly.
Discussion Starter #19
okay, if if you look at the pictures I want something that will lower the back so it isn't as high, I do not typically not drive hard at all, usually driving from home to school usually in the range of 30-40 mph. So I don't need that demanding of coilovers. What would you guys recommend? I'd rather not spend $900+ on coilovers but if that is the only option you guys reccommend sure but what is good for something that is a bit lower in price?
777
honestly, you could stick TRD springs ( or similar ), on your stock struts and be fine for a couple thousand miles
i believe with the small drop the trd springs ( or tein s.? i believe ), stock struts can handle the drop for a while, but they will eventually blow out, ( if they already havent)
lowering springs aren't more than 200 for the set, it's just labor intensive to switch them out, but if you do it yourself it's fairly easy.
tl;dr buy cheap 1.2 inch lowering springs, stick on stock struts, slightly improved ride look, while not spending a bunch on coils you say you don't want.
1 - 20 of 21 Posts
