so i plan on running about 15psi on a intercooled supercharger ass well as a 100 shot of nitrous. You think the pistons alone are a good enough upgrade for the block?
If it were me, I'd go with the Mahle pistons and MWR Bearings for the bottom end. The stock 2zz rods are pretty beefy.Korben007 said:so i plan on running about 15psi on a intercooled supercharger ass well as a 100 shot of nitrous. You think the pistons alone are a good enough upgrade for the block?
is there an echo in here? that sounds exactly like what i would say.vip09 said:If it were me, I'd go with the Mahle pistons and MWR Bearings for the bottom end. The stock 2zz rods are pretty beefy.
jlitman said:Sorry to dredge up an old thread, but why exactly are MWR's set cost ~$200 more than purchasing them straight from Mahle? I don't mind the cost if there's a reason... just like to know.
Also, what about these problems noted on moremonkey... http://www.monkeytuner.com/forum/viewtopic.php?t=915&start=15
Wouldn't it be safer to order them directly from Mahle, especially if they may need to be returned to them...?
I kind of have an answer to this:Celicasaur said:jlitman said:Sorry to dredge up an old thread, but why exactly are MWR's set cost ~$200 more than purchasing them straight from Mahle? I don't mind the cost if there's a reason... just like to know.
Wouldn't it be safer to order them directly from Mahle, especially if they may need to be returned to them...?![]()
bump
(just to clarify, i know what he means, i want to know the answer...)
If you need to ask these questions, you need to let a machine shop do the engine work.DaElongatus said:guys PLEASE HELP ME WITH MY QUESTIONS !
mahle pistons is very tempting.(too good to be ture?)..
my questions are that do i need anything else to put in the mahle pistons?
how hard is the install and how long?
how much would it cost me for install at a shop?
do i just take off the head and pop them in?
how much boost can i run safely with the GT28RS turbo with large IC(w/pistons)?
what kind of power should i be expecting running safely(w/pistons)?
THANK YOU VERY MUCH
I was thinking that may be the answer...jlitman said:I kind of have an answer to this:
MWR does nothing special to the pistons -- consider this the "guaranteed in stock" mark-up...
Yes, you are, I really want to know how much an engine build in the UK costs!Celicasaur said:I was thinking that may be the answer...![]()
I think I may well do the same as you and order from them guys and wait a little longer. It's not like I'm in an immediate hurry I suppose...
vip09 said:If you need to ask these questions, you need to let a machine shop do the engine work.
Call around to different machine shops where you live and get some quotes.
MWR is running over 500whp with the mahle pistons and MWR bearings.
Since you didn't mention any fuel upgrades, your power potential would be around 210whp safely if I had to guess.
Mahle, yes; Wiseco, no. Moreover, the 2ZZ block has a special MMC coating on the cyl walls that cannot be honed without special tools. On top of that, everyone I've spoken to says that getting the bore right on the 2ZZ block is tricky, so if you need sleeves, the recommendation is to just buy a sleeved bareblock from MWR.DaElongatus said:ive rc550 injectors/pe210 fuel pump.
my questions is that can the shop just swap in the pistons/bearings without machining the block?
Yep -- Boosted tried to explain this to me recently, but it went a little over my head as I'm not to savvy on the science / voodoo of engine building... but that's the basic idea.Celicasaur said:Is it true that the mmc coating is there to help reduce the amount of bore wear over time with such high revving engines such as the 2zz and H22?
There is indeed - and Google also found me another PDF on the 2ZZ-GE design - I hope the links work for you...jlitman said:Yep -- Boosted tried to explain this to me recently, but it went a little over my head as I'm not to savvy on the science / voodoo of engine building... but that's the basic idea.
Actually, I beleive there's a technical paper on the 2ZZ floating around that explains the reasoning behind it...
Yep, thats why .5mm overbore forged pistons have been available for years.Gravel said:I didn't realise the 1ZZ-FE has iron liners :shrugs:
Why do they need to be overbore though - surely removing some of the iron liner to fit them in is a bad thing? :shrug:wts said:Yep, thats why .5mm overbore forged pistons have been available for years.
And then the next thoughts are, would it possible to get any forged piston of the right size etc, coated in this stuff to be compatible with the 2zz boreGravel said:As for the MMC 2ZZ - notice that the pistons have to be coated in Fe-P - Iron Phosphide - is this what makes the Mahle pistions special?
According to Mahle:Gravel said:As for the MMC 2ZZ - notice that the pistons have to be coated in Fe-P - Iron Phosphide - is this what makes the Mahle pistions special?
The Wisecos don't, which as I understand it, is why you need sleeves that can be easily machined to the correct specs, whereas the OEM bores are pretty much impossible to hone.Celicasaur said:And then the next thoughts are, would it possible to get any forged piston of the right size etc, coated in this stuff to be compatible with the 2zz bore![]()
