1 - 3 of 3 Posts
Well what you can do to make it work is this. Remove your shifter out of the assymbly, take the stock shift knob off, cut 2 1/2 inches of the top (threaded side) and also move the pivot ball up 1/4" then use a tap and die set to find out what the thread is on the mazda 3 shift knob and rethread the shifter shaft for the mazda knob. That way will work
1 - 3 of 3 Posts
