1 - 9 of 9 Posts
How do you change the head lights on a celica?... do you have to take the whole head lamp out or can u do it wiht everything still on?, i cant get the old light out, an i can barely fit my hand in there as it is.. and when i get ahold of the light, it wont twist out or anything, any screws or a pin holding it in?
Discussion Starter · #2 ·
Work Done, Sexy Time.
Lark, my boy theres like a gate that holds in the bulbs. You have to push the gate in at the top and then pull it up a slight bit and then it will swing out. Then you can access the bulb. Make note that the bulb is keyed. There is a top and a bottom to the bulb fitting in the socket. You should be able to change your bulbs no problem now. You need more help pm me
ok, got it...what'a pain in the ass
lark are you going to consider hids???????.
Even mine are a pain... the left side can only be reached by putting you hand next to a jagged part of the cars frame.
Just wait until you accidentially knock the gate off :mad:
BE GENTLE
I had to remove the whole assembly. (The last bolt is behind the nose cover towards the front of the head light assembly - just in case) ;) (the highbeams are really hard to reach)
it makes it much easier if you take one of the housings off the first time, and really get a good look at how it works. I just happened to be putting in an intake at the same time as I got my bulbs and already had the bumper off so that's what I did. Since then i've changed the bulbs without removing the housings, it takes a little patience to get that damn clip on, and if you knock it off, i'm sure you'll have to take out the housing to put it back on.
1 - 9 of 9 Posts
