so I got that baby hooked up, pretty straight forward and the real time monitor is very cool, however it's all in european measurements: instead of PSI we got Kg/cm2 and instead of mph we got kmh
2 questions:
1) Is there a way to change the display to american measurements, I looked at the manual and did not see anything
2) If you can't change the display does anyone know the conversion from Kg/cm2 to PSI since european lbs are different than american I am not sure a regular conversion chart would work and screwing this up is a bit dangerous since I'm running 11 psi
2 questions:
