1 - 12 of 12 Posts
I had really been looking at making blue gauges, but also was looking for some red in there as well. I originally ordered Russ' black and blue gauges, but the numbers were impossible to see during the day. So I returned them for the black and white gauges and decided to do some customizing on them. Here's a pic of the standard black/white gauges I'm sure you've seen.
And here's them held up to a white backlight. I used colored filters for stage lighting on the back side. In the car, they will be backlight by white El sheet, and the needles will be red.
So what do you think?
J3adSeed said:
i think they make reverse indiglos identical to that. especially if you're using a el sheet to light it up anyway.
No. They make SIMILAR ones, but only for a GT. Hence why I had to go this route... Plus, those ones have a white face, which I think looks like poop.
If you use EL sheet for lighting how do you see the engine check, high beam, door ajar, and all the rest of the car status lights?
as soon as i find the time to finish the artwork... I've been overwhelmed w/lots of stuff lately (past 3 months :( )
The same way I managed to not cover them over with the colored filters :wtf:
1 - 12 of 12 Posts
