1 - 1 of 1 Posts
I installed my S-AFC today, and I want to post my settings and idle values, etc. for everyone. This is not only for reference, but I also have a few questions to ask...
Okay, here goes:
Throttle Points: High-55%, low-20%
On the sensor volt check, In1 was around 1-1.15 and In2 was 0-.7
Are these normal values for the readings?
I have the sensor set to hotwire 01/01
Here are my High/Low Corrections:
Low (1st setup) High (1st setup)
1 -1%(-1) +1% (+1)
2 0 (0) +13 (+14)
3 0 (0) +16 (+16)
4 -1(0) +3 (+3)
5 -1 (-1) -4 (-4)
6 0 (0) -6 (-6)
7 +1 (+1) -5 (-5)
8 +1 (+1) -7 (-7)
I had slightly different values input beforehand, then I Initialized the AFC and reset them. I recorded the idle values of the following at all points:
1st Value Initialized 2nd Value
Air Flow 1.2-1.3% 1.2-1.4% 1.1-1.2%
Pressure -760 - -740 -760 - -740 -760 - 755
RPM 830-870 860-890 770-795
Correction -1.0 0 -1.0
Which setup was better. For example was it better with a lower idle RPM and other values? This is all just temporary until the dyno opens near me BTW. And I know that idle is different from WOT, but the idle value can tell quite a bit about the performance
Edit: I forgot: What the hell is the Sensor Calculation? How does it work? I would appreciate any opinions on any of this and also any same or different values anyone else has gotten, tuned and untuned with a dyno.
1 - 1 of 1 Posts
