I was on 710's. I ran them all day on Tuesday, and ran my street 712's for first run on Wednesday. I put the 710's on for 2nd and 3rd runs. They worked great in the wet.
The 710 works very well. I've been using them since Cendiv Divisionals at the beginning of August. They work well both cold and hot, forward bite is great, you can launch them quite hard. I've not driven the S04 Hoosier yet, but they compare quite well to the S03.
I wish they made a 225. I know I'm giving up some contact patch to the Hoosier.
With two drivers, the tire can get very hot. We measured temps over 200 at Divisionals. The tires continued to work until the very last run, when they started to get greasy. We were spraying water on the fronts, we used a whole garden sprayer bottle.
The tires I used at Nats then went to an ES/ESL MR2 for Thur/Fri. Four drivers used those tires, and took two more trophies.
Carpenter ran 710's on the front, and by third runs on Tuesday had put Ecsta V700's on the rear. He was trying to get more rotation in the car.
