Ok, so some of you may remember that I just changed my lift bolts the long way and after putting it back together the car wouldn't start. So I took it all apart again and found out the timing was out about 90*. So i put it all back together and voila, car starts. Idling rough as hell and barely move in gear. So, I tear it down and adjust the exhaust cam(looking at the sprocket turn it 1 tooth clockwise) and put it back together, and voila, car runs smooth while idling, but rough as hell when in gear trying to move. So, I get out my OBD II scanner and what do you know, I have a cylinder 3 and 4 misfire and 02 heater circuit code come up. P0135 was the code i believe.
Does anyone know how I might go about fixing the 02 circuit heater problem or fixing the cylinder misfires?
Any help is much appreciated guys:wiggle:
