1 - 11 of 11 Posts
Ok guy i got my car from the guy working on my head, and helping me with my broken rocker. I inspected the car and find this hose, its a metal line like how the fuel line is, and its just open right there next to the battery. I thought it might be some type of vacuum or fuel related. BUt my car idles fine, gas mileage seems to have gone down a bit. here are some pics, it goes metal line to a rubber line and it has two clamps on it like something used to go there. Mechanic said it was my CAI that deleted the use of it but i have never seen that line in my life. Thanks for the help guys.
any ideas? thank you
well thing is i check my CAI first. and nada. Everything is all connected. Mechanic said he never touched it in the first place. And its like right next to the battery hovering above the tranny
03GTSTRD do you have that hard metal line by the battery tuning to a rubber line going to the CAI?
k thanks let me go check one more time. brb
lol hey 03GTSTRD i got it thanks, lol the line was hiding under the ECU and better. Do you think it would affect my gas mileage? an yeah it hooked right up thanks
I am glad I was able to help you man!:thumbup:
I am not sure but I would think that line being loose could have caused a drop in gas mileage.
Discussion Starter · #9 ·
hmm maybe lol thanks again lol can close thread :)
Its supposed to hook to the green service port for the EVAP system
It was probably causing an unmetered vacuum leak actually which would have been causing misfire, which would probably have been affecting your gas mileage as well.
Over time it can also cause your cat to die.
Interesting...Might be what's causing my issue as well, from what Boosted2.0 said it lines up perfectly with what's goin on in my celi. Now if only it'd warm up a little over sub-arctic temperatures so i can take a look-see.. >.>;
1 - 11 of 11 Posts
