1 - 4 of 4 Posts
I am loosing pressure when applying my brakes and loosing fluid. I changed my master, checked my rubber lines in all 4 wheels and calipers and can't find any leaks. Also checked my clutch line and all good.Any idea where I could find more where my leak would be?
Make sure the fluid is full, park in a clean dry spot, and with the car running pump the brakes for about a minute, then roll the car back from the spot and see if there's a puddle. That'll give you an idea what area of the car to start looking at.
FYI....when installing a new master it might need to be bled before installing...also did you bleed the calipers?...really old fluid also feels that way if you haven't flushed it already
1 - 4 of 4 Posts
