1 - 9 of 9 Posts
alright i installed my in dash tv in my celica and im having no problems with anything acept getting the video to play. i want to get it so it will play videos without my parking brake on, i talked to the guys at a local audio shop and they can put a switch in there for me but i figured i might could save a couple of bucks if any of yall know how to do this. i figured ive gotten this far without help theres no reason to take it to professonals anyway if any1 knows anything about this mod please help
PARKING BRAKE
parking brake inhibit
When the pink "parking" wire is connected to the vehicle brake switch, the front TFT monitor will display video only when the parking brake sequence is engaged. Before starting the parking brake sequence, the radio must be on with the video media disk inserted and playing.
Parking brake Sequence
There are two situations that can start the Parking Brake sequence (this is the prefered method). The timing window is between 3-5 seconds.
*Parking Brake is engaged (on) when the vechicle is started or the accessory/ignition is turned on. To activate video, the following sequence of events must be completed.
a. Release parking brake 3-5 seconds
b. Reapply parking brake
c. Video should be displayed on the TFT monitor
ok i went to the audio store and they told me this code to bypass the parking brake method thing, thanks for your help anyway
· 12+ years daily driver
which headunit did you have. When I installed mine I just grounded it to the parking brake instead of wiring it into the parking brake activation switch and it worked fine. But then again my deck wasn't one with a flip out screen, I have an external.
The low end ones you can just ground and it works, the high ends you need a full bypass unit, there are also ones you can program like yours where there is a factory code you input to bypass the parking inhibit
1 - 9 of 9 Posts
