Hey guys. I have been browsing this forum as a guest for the past couple weeks and finally decided to make an account. I couldnt quite get my answer just looking through existing threads. So here it is.
Recently I bought a 2001 Celica GT with 144,000 miles and drove it home from Nevada (1800 miles). Its a great runner and yes it consumes a little oil but not too bad considering the speed limits in Utah. Anyway, when I first bought the car, I noticed it had 5W-20 in it. That is what the oil change sticker indicated. The only problem during the entire trip was when it rained heavily near Mt. Rushmore it started sputtering. I have already resolved that this was hydrolock from the CAI and plan to create a better splashshield for it.
After it quickly burned up the 5W-20 cruising around Vegas I decided to switch it to 10W-40. Ever since I have had the car, though, there is a rattle in the top end of the engine between 2700RPMs and 3500RPMs. If I am light or hard on the gas it is much fainter. It seems like when the car is under heavy load it is fainter (up a hill etc.)
After browsing the forums here, I decided to clean the OCV filter really good. Before I put it back in it looked like new, no metal shavings, nothing. Virtually spotless. I did not pull the valve, but I can if necessary.
I did see a couple other people seemed to have the same problem on here but it went unresolved. The idle is almost perfect but it seems a little high when cold starting (holds at about 1500RPMs) Once down, it idles well but, on rare occasion stumbles from about 800RPMs to 650RPMs.
Keep in mind that the rattle is not as definite as some of the rod knock videos I have watched, nor does it rattle across all RPM ranges. This is the only issue with an otherwise flawless, clean southern car so its rather annoying.
Also, the car has a full DC exhaust and switched to 91 octane gas, did three bottles of injector cleaner (in three full tanks), and when I pulled and replaced the Autolite plugs that the previous owner had used, the plug tips where very white which usually indicates lean. I changed to NGK.
I might be forgetting details so feel free to ask questions.
P.S. does anyone else notice that third gear int he 5 speed manual is useless? LOL I just shift from 2nd to 4th now because 3rd isn´t even helpful unless your trying to pretend its a race car which I dont.
Thank you in advance for any help with this.
