Here we go,
I got my C2Power stage 1 turbo installed 2 months ago.
MY stock clutch wasn't up to the power so I ordered a SPEC clutch (Stage 2, kevlar disc) and a SPEC flywheel.
I got it installed last tuesday, since then I drove about 350 miles pretty easy, I did some hard accelerations now and then, but only with the clutch fully up.
Tonight I drove a bit and since I am getting used to my new fw I was taking off while slipping the clutch more than needed. After that I felt it slipping in 3rd
I drove 100 miles before that and no problem at all.
Three questions...
1st
Should the garage have bled my clutch after installing a new one?
2nd
Compared to my stock clutch it engages almost at the top (last 2 cm), while my stock clutch started engagement when I lifted the pedal about 1 cm. Could it be my clutch is not fully engaging? Should I just bleed my clutch line?
3rd
Could it be I am still in my break-in period? I let the clutch 'cool off' a while and then it didn't slip anymore.
I am a bit clueless about what it could be, I will try to adjust the rod behind the pedal tomorrow (no 12 mm wrench) and see if that helps anything.
Any suggestions or possible solutions are greatly appreciated..
Three questions...
1st
2nd
3rd
