I have a 2000 Celica gts. I have a brand new oem head and I also purchased a brand new oem short block from MWR and had the 12.3.1 pistons put in. They put the block fully together then shipped it to me. After having my engine put together and installed I have a deisel knocking sound only when the car is in gear and any % of throttle is given. Sounds fades as less throttle. Does not get louder with more throttle but does however speed up with engine. It's not loud but is noticeable. The car sounds perfect at idel and even raising RPM while in neutral , just makes the sound while in gear with any kinda of load on the engine.
I now have 200 miles on the engine. Valve clearances have been checked and are perfect. oil level is fine. Still running thick GTX 10w 40 during break in.
Wide band reads between 14 and 15 or so during normal driving , 13 during full throttle.
Normal driving LTFT constantly ask for + 25 on even just 10% throttle ( may be more and my computer only reads up to 25 I'm guessing. )
IAF 113
MAF 2.8 to 3.2
Ignition is at 22 to 23 degrees.
93 octane gas
BTW car dives great.
These are some figures that MWR asked for in a attempt to help figure this out. I just haven't talked back with them cause it's the weekend. I'll be calling tomorrow. I also understand MWR is on here so I was hopeing to discuss I case some one else has had the same thing and can help.
Ive had multiple shop mechanics ride and listen and no one can seem to figure it out, some have speculated piston slap but weird it don't do it at idel. Last guy guessed its to lean do to the numbers I posted and MRW is so far saying it could be detonating , but they were needing these figures. I'd be happy to give any of you my phone number to talk about this issue if need be. I would appreciate any feed back.
IAF 113
MAF 2.8 to 3.2
93 octane gas
