1 - 4 of 4 Posts
i got my check engine light checked out from 2 different sources, both said it my bank 1 o2 sensor (which is in front of the cat, correct me if i'm wrong) but i also have one of those cheap ebay cai so i was wondering if maybe that was causing the cel. any feedback would be great. thanks!
what was the code exactly?
Zettai Unmei Mokushiroku
I've heard O2 sensors tend to go bad around 100K, but there's always a chance you got a faulty one. Do you know anyone who has a multimeter you can borrow? I can give you the specs so you can test out the sensor. There's a good chance the CEL is being caused by the CAI, though it rarely tends to happen with the eBay versions.
I had a problem w/ my O2 sensors too, they were "heated" or something. Car was running extremely rich. After a bunch of trial and errors in my part to fix the problem and I took it to my mechanic at Toyota. Then we both tried to figure it out and then I suggested it had to be the ECU. It was replaced under warantee (ECU warantee is 80,000 miles). Now its running w/ no problems. If you happen to not have the warantee ecu is about 800-900ish, but I think you can say that it wasn't you're fault it was theres etc. Hope this helps
1 - 4 of 4 Posts
