1 - 13 of 13 Posts
...guess where the other half is :faint:
it's a 2000 69k miles...i was installing boosted's header, when to install my 3rd gen's as pictured...and pretty much threw the bolt across my garage when only half came out
hmmm...always something...:rolleyes:
I am going to try the extraction method using sears tools first...i am wrapping the remaining part of hte drill bit in electrical tape then putting a rubber electrical shrink tube on hte bit, and heating it up...that will eliminate damage to the cam threads, hopefully........
Ultraviolent
threw the bolt across my garage when only half came out hmmm...always something...:rolleyes:
I know id do the same, g-luck with the extraction, imma change my 04s when i hit 50k which is about 8k away, i got my fingers crossed:gap:
if it works, I will post up my method...
that sucks :eek:
i remember watching smaay remove a broken one and it was no easy task :ugh:
Ha! goodluck and have fun.
I did broke one of my exhaust manifold's bolt. I end up spending a 90 degree drill with reverse and key lock and bolt extraction kit.
Not an easy task but it will be a good experience.
1 - 13 of 13 Posts
