1 - 4 of 4 Posts
Years back I had my radiator replaced due to some front end damage and the shop that did the body work put in the A/T radiator, at least that's what it looks like.
On the A/T radiator it states that there is an "oil cooler" incorporated into the radiator on the passenger side.
I assume this is used to cool the automatic transmission fluid, but can it be used to cool motor oil also? With some modification of course.
Just curious.
Assuming you have a manual and no a/t fluid to cool...
That cooler is for the a/t fluid. In theory, you could use it for regular motor oil as well (B&M's Supercoolers are designed to handle both). However, the automatic tranny generates something like 6 PSI of pressure at idle in Park. I don't know how much is generated under load, but I would question whether that cooler was designed to withstand the same pressure as the regular oiling system (something like 100 PSI, right?). Additionally, IMHO the stock cooler is a crap design and doesn't get much direct airflow.
1 - 4 of 4 Posts
