1 - 4 of 4 Posts
So I was merging onto the parkway today, dropped a gear and pushed it to hit lift. As I hit lift, the engine bogged down, no power, no acceleration and the engine makes loud ticking noise. It basically sputtered and died right as when I stopped on the side of the highway. It does start back up again though. Barely goes anywhere in 1st. I had to have it towed home. I scanned it and I got a p1693 and a cat efficiency below threshold But it's been going on and off for a while. Did a compression test and it was okay, a little on the low side though. Brand new supertech valves about 500 miles ago. Open up the valve cover and smells a little burnt. I do keep up with my oil maintenance. What could it be? Failed oil pump?
1 - 4 of 4 Posts
