1 - 20 of 67 Posts
I thought circuitworx stopped making them??? I was thinking about seeing a CNC machinist around here to make some.
So they still make it then?
I don't know, I haven't bought one in years, but they have them listed on the website. You'd have to phone them up and ask if they have any stock or if/when they are planning to do a production run.
All I can confirm is that prodrive was renamed to circuitworx (I think because prodrive in europe came over to american and wanted their name) and that is the same billet steel oil pump gears everyone here was buying.
They don't makew it anymore - lilrocketspyder is going to get some made up by another company though I think
well I emailed them some time back and they said they where making a new batch but have not contacted them after that. So there is possibility they still make them
does the elise use the same gear/pump?
Awhile back I had e-mailed them because they still had it listed as an available application. They responded back saying that they (the pump gear) were not available anymore, they had no plans to make anymore, and that they had just forgot to take it down off the application list. :shrugs:
S|Lv3rBu||et said:
It uses the same engine so, yes! :thumbup:
apparently they use the K series (rover) engine.
just got them on the email. so, it seems we are out of luck from eliseparts.
on the otherhand, Circuitworx says no ex-stock, but will be able to produce in a month. maybe i will get it from there.
Not exactly sure what you mean by K series (it's definately not a Honda K series)...it's pretty much the same exact 2ZZ that we use in the Celica GT-S, Matrix XRS, or the Corolla XRS.
the older gen Elise 111S uses the rover K series engine before lotus opt for the Toyota/Yahama 2ZZ engine.
i believe the fellow there knows what he is talking about. heck, they do Elise for a living.
the newer gen Elise 111R onwards, and the Exige, 240R, S, uses the 2ZZ-GE.
more info:
http://www.elises.co.uk/models/index.html
more info:
It was pretty obvious that the two people quoted were referring to the current model Elise.
Keep us updated if they make the pump again, cause id love to do the crank pulley from Unorthodox, but dont want to take risk of oil pump failure.
Yeah but the part he linked to wasn't for a 2ZZ Elise.
Ah, I wasn't looking at 04gt's post....that's why I had no idea where the older Elise engines came in.
1 - 20 of 67 Posts
