1 - 10 of 10 Posts
Ok on an auto car yeah yeah I know an auto what the hell, anyway up byt the gear shift selection tool while in park you will notice, if you look a little plastic oval piece up near the P!! Ok well the other day I removed this piece and looked under it cause I was curious, and low and behole there was a button now can anyone tell me what this button does or is???? Check it out and lets see if we can fiogure out what it is!!
Justin
that is shifter release..you can put your key in it and then you can shift out of park without having the keys in the ignition
o is that it
what the hell is the point of that???
thats great be good info. for all u car gankers out there
Justin
Or if your car is needing to be towed and they dont have your keys :) LMAO
There is a solenoid that locks your shifter in park unless you have your foot on the brake. It is relaeased electrically, so if your battery goes dead your car is stuck in park. The release button will let you shift into neutral so that you can move the car around if that happens and you need to move it to get a jump or whatever.
1 - 10 of 10 Posts
