P1692 anyone know this one
1257 Views 2 Replies 3 Participants Last post by  Littleman54
P1692 - Toyota Type Powertrain - Manufacturer Controlled DTC -Manufacturer Controlled
Description Variable valve timing - malfunction
Cause Wiring, valve timing sensor, ECM
KINDA stuck on this one.
1 - 3 of 3 Posts
It's most likely your ocv or the connector that connects to the ocv. Check both. Also, you can check your oil pressure sensor as well.
1 - 3 of 3 Posts
