1 - 13 of 13 Posts
I want to paint the s200 antenna to match the color of my car. If I paint it with regular paint it will look shiny. I want to go for the same dull look. Has anyone have suggestions on what to use?
I would think liquid latex would work well too. Maybe thats what Dooly used
Discussion Starter #10
wgaughan said:
Try the SEM dye that has been talked about so much in other threads. What color is your car?
it's spectra. where could I get it?
dooly said:
Rubber coating
will it have the same dull looks as the original black antenna?
i don't like it to be shiny.
KSilver2000 said:
What is rubber coating? And is it flexible enough to play with it and not come off?
It's stuff you dip your tool handle to have better grip..
I've only seen red and black color...
YES.. this is ultimate flexible.... it'll flex as much as you can flex with your antenna.....
Why you want to play with it??
YES.. you can play with it much as you want.... weather resistent....
1 - 13 of 13 Posts
