i just got done installing ZEX kit on my car, and wondering if I still can have PFC and would my nitrous benefit from it
No, it doesn't do that.bigjuice61 said:question is there a nitrous map in the power fc i mean like a real one that will pull tyming and adjust fuel when the bottle is activated ?
Smaay said:you can make a map for squeezing. and when you are normal driving it will be a little under powered. thats all.
well...i guess that clears a myth up about itSmaay said:you can NOT have 2 map's in the PFC at the same time, you have to load one or the other
true, but it would be so much more easier to just have it safely set up for nitrous use and normal driving, rather than having to load up the computer in the car at the traffic lights right before a spontaneous race.blinding-gts said:You could also get a cheap laptop and keep it in the car for when you want to switch over maps. I have a tablet pc that I use in the car for tuning/etc which I use from time to time if I need to switch/test maps.
Out of curiosity, what if he used the PFC with a J&S Safeguard system along with a colder range of plugs. Would this be enough to leave the PFC map alone?
