1 - 1 of 1 Posts
1999 Toyota Celica T23 S
Hey guys,
Could someone please make some pictures of the stock rear sway bar from these positions:
You might ask why I need these pictures.
I just got myself a set of Whiteline sway bars.
However, I doubt that the rear sway bar will fit correctly as the upper picture (right hand side) shows that the end is about 1.2cm/half of an inch up in the air while the other end (left hand side) is almost completely on the ground.
Whiteline UK is currently checking this topic with R&D and asked if I may take some pictures of the stock sway bar.
As I need the car currently there is no way to remove it.
Can you confirm that the rear sway is fine/faulty by uploading pictures from these positions?
Thanks in advance.
1 - 1 of 1 Posts
