blazin-sc said:
I have a BS in EE. You probably dont even have a HS diploma.
I have a high school diploma, thank you. I'm am going for a BS in Mechanical Engineering and a BS in Materials Science. I am in my 3rd year now, so I've taken plenty of electronics classes. The fact that you are saying you are an EE and can't understand Ohm's Law makes me wonder.
blazin-sc said:
I dont know what eqns you had but something just isnt right. 4 - 4 ohm loads in parallel is 1 ohm.
I never questioned that. I just said he shouldn't do that.
blazin-sc said:
The parallel impedance eqn is the following:
1/Rf = 1/R1 + 1/R2 .... you need to invert that eqn you had.
Dude, you just kicked yourself in the nuts on that one. I posted the equation that:
1/8 + 1/8 = 1/4, which is the exact same as your equation 1/R1 + 1/R2 = 1/Rf. Are you actually reading these posts??
blazin-sc said:
That amp that he has can handle 1 ohm.
According to JL's website, that amp should be run between 1.5-4-ohms. Sure, it might be able to handle 1-ohm, but why? The amp puts out the same wattage at 4-ohms as it would at 1.5-ohms. I've called JL Audio (since I'm on their competition team), and they do not recommend 1-ohm on a JL amplifier. Call and ask if you want.
Dude, I would love to continue going on about it, but I won't. I think you just need to re-read my first post, then read yours. Maybe you were paying attention and it was a simple mistake. Whatever. I don't want to turn this post into a "mine is bigger than yours" thing. If you want to, go ahead.
Curt
BTW, I don't have beef with you. I just have beef with people that post bad information for others.
