1 - 4 of 4 Posts
I want to ditch my ST rear sway and get the Hotchkis street set.
My concern is that my suspension is pretty well balanced in terms of under/oversteer now. If I put a bigger front bar on now it will oversteer as much as it did when I was stock. I like my setup now but I do want less body roll ( only gonna happen with sway bars).
What do those that have both Hotchkis sways bars have to say?
I do push my car to limits and would really like to have just a bit of understeer in my final setup.
My setup is:
Stock Shocks-still dampen well
TRD Springs
RMM Front Strut Bar
Cusco Lower Tie Bar
Tanabe Lower Bar
ST Rear Sway Bar
Hypermotive 2 pt Rear Strut Bar (planned purchase)
Thanks All
i had both. Wait til your stock shocks get a little more blown, you will wish you had the full set. what kind of tires do you have. I had the ST rear, and it kicked my ass end out on me a couple times in high speed corners. The hotchkis setup is much more stable. You can also tweak the front a bit to make it a bit softer, and if you had teins (like myself) you can adjust the endlinks too to be softer or stiffer. I say go with the hotchkis, but you should also seriously consider trd shocks while you are at it.
1 - 4 of 4 Posts
