1 - 9 of 9 Posts
I just went out to Advanced Autos and bought these blue lights that are waterproof.. I plan on installin' it on my front bumper where that lil' grill area is on the 03' model.. thing is i dunno where to connect the wires to.. the lights have a blue/red/black wire and a lil box thats located in the middle of that wire.. i want it to go on when i put my alarm on.. so does anyone know where i should hook this up too?!? thanx
got a picture of the group of stuff? and exactly where you wanna put em?
this is where i plan to put them..
<img src="http://www.t-mobilepictures.com/photos/photo02/6e/24/0113204f5f93"
and heres the pictures of the object
<img src="http://www.t-mobilepictures.com/photos/photo04/a8/43/1f2797109f24"
ok well.. if the lil box your talking about has a knob on it then that would be to adjust brightness im guessing... that you would want some where close to the driver seat so you can adjust it and what not.. but if its not i unno... onto the wiring question.. if you want a switch you would run the power wire to a switch then have another wire running to a power source (ie, cig lighter, etc) then you would ground it with the grounding wire anywhere that touches the frame.. im not sure about the 3rd wire..
in most cases the 3rd wire is the remote on. so it could be that u have 1 ground, 1 always on power, and 1 that turns on say when lights turn on. but try jsut hooking it up to ur battery terminals w/o the blue wire and see what happens. then put black on neg and red/blue on pos and see what happens
1 - 9 of 9 Posts
