1 - 19 of 19 Posts
There are two hoses that you pull out of the stock air box (NOT the butterfly valve). They are adjacent to each other and one is larger than the other. Do one of these go to the sri tube? What do you do with the other?
New Kid
I've read like 10 different install guides. I'm having trouble understanding just that one part because I don't see where that's ever mentioned.
Ahh. Okay. Well You mean the two tubes that come from the block into the stock airbox?
I may be wrong but I believe those stay with the stock airbox. Only one tube should be going into the sri. Ill have to check when I get home.
I'd appreciate it if you could check when you can. My intake does only have one vacuum port and I'm not sure which line goes to it.
Two of the hose goes into the EVAP sensor. You won't be needing any other hose.
This hose is suppose to be cap. where are you connect this?
1 - 19 of 19 Posts
