1 - 7 of 7 Posts
I'm back :)
I have an Injen CAI, how often should I change/re-oil my air filter.
i'd say re oil it like every 3 months? Someone correct me if i'm wrong....
i have never re-oil my filter, it's running fine...reason is, i don't wish the MAF sensor to be caught w/too much oil...
Zettai Unmei Mokushiroku
You don't have to reoil the filter unless you clean it. You shouldn't have to clean it for at least 10K. Remember when you oil it, it only needs a VERY light misting. After the first drive around the block, clean off your MAFS, since oil will collect on it after the filter's first use.
ok here's adding to the newbieness...
1) what kind of oil do you use?
2) where can you get it?
3) how are you supposed to clean the filter?
4) how do you clean the MAF?
sorry for so many questions...gosh i feel like a newbie.
1. K&N filter cleaning kit oil.
2. Any auto store should have it.
3. Spray it down from the outside with the cleaner, let it soak for a few min, rinse it out from the inside with cold water only, let air dry.
4. Spray it with non-chlorinated brake cleaner.
1 - 7 of 7 Posts
