1 - 7 of 7 Posts
yes, i didn't clear the curb, i pulled about 2 feet over it, then reversed off. i haven't driven it, just parked it, and deciding if i should tow it to the dealership. what would you recommend?
i hope the tube leaking is just my air conditioning , but now that you mentioned my sway bar shifting, how serious is a shifted sway bar?
That's a drain line for the AC (or sunroof) no worries there, it's supposed to be leaking.
As for the sway bar, I suspect it will recenter itself after a few miles of driving (not a big deal regardless). For all you know it's already recentered, and all you see there is a clean spot where it shifted and cleaned the bar, then shifted back.
1 - 7 of 7 Posts
