1 - 9 of 9 Posts
I have had a persistent CEL for a while now with the following codes:
P300: random cylinder misfire
P303: cylinder 3 misfire
'02 GTS. Symptoms: hesitation in the morning or when the engine is cold; engine sputters lightly pretty much all the time (can be heard from the air intake and exhaust).
I really need to take care of this if I want to pass another state inspection (that's been expired for over a year and a half now.. whoops). The only relevant mod that I can think of is the Injen SRI. I did the BB mod since I've had the problem, but the codes have stayed the same.
[Engine Bay]
Troubleshooting I have done so far:
- cleaned the MAF sensor multiple times
- replaced the spark plugs (iridium); moved the spark plugs and the coils around, code P303 stays on cylinder 3.
[Spark Plugs]
- ran fuel injector cleaner through the gas tank
- sprayed intake cleaner around the manifold area to see if any leaks would show, but did not notice any difference
- seafoamed the car
- ran a cylinder compression test today, got 151, 154, 147, and 155 psi for cylinders 1-4 respectively. This is lower than normal, no?
My mechanic said they took out the injectors and cleaned them, but I will check them again myself. Besides that, I'm not sure what else I can besides take the manifold off and take a look (never done this before, so I wouldn't be sure what to look for). My shop said it'll be around $2K for them to take the head off the motor. Any suggestions or ideas of what I can do myself?
Thanks for the quick responses guys. I will try swapping the injectors.
I've been using 89 gas for a few years now, so that shouldn't be an issue...
I had a similar issue, random cylinder misfire and misfire in cylinder 4. I went through sparkplugs, changed the coil packs and the maf sensor. at the time I had other issues, so I changed the o2 sensors. After all that, I swapped out the injectors and the car stopped hesitating. if you switch out the injectors and your still having issues with that cylinder, you internal damage
I have additional info I forgot to mention. I got a code reader, and it tells me that the following monitors are incomplete, even after driving thousands of miles:
- Catalyst
- Evap
- O2
Not sure if this will support any of the theories above...
Discussion Starter · #9 ·
Checked my injectors, one of them was missing an O-ring at the top, so it was loose in the fuel rail. Replaced O-rings on all of them, put them back in. I believe it got rid of hesitation, but the codes came back the same.
1 - 9 of 9 Posts
