1 - 2 of 2 Posts
is it possible to install the GTS rear disc brakes on a GT which has drums??
thanks
and anyone sellin if it works or wherie can get em?
thanks
Black Celica GT 2000
TRD Leather
Racing Seats (Red/Black)
Injen Short Ram Air Intake
Ignited Push Button Engine Start
Racing Hart M5 18"
Pirelli P7000 SuperSport
H&R Sport Springs
15% Visibility Window Tint ~ Llumar
RAZO Aluminium Racing Pedals
TRD Black Carbon Fiber Shift Knob
TRD Black Shoulder Pads (in rear)
S2000 Antenna
Apexi Turbo Timer (New Model)
Wings West V-Line Rear Wing
Clear Bumper Lenses
DRLs disabled
Super White Everything
Redded Out Tail Lights
GTS Rims as Winter Tires Yokohama A520
On The Way...
Kaminari Body Kit
Yes it could be done, but if you have to ask, then you uprobably shouldn't try it.
Minimum set of parts...
1) Rear hub with brake assembly (just unbolt the parts from the rear control arm of a GTS). That should get you all the hardware. Make sure you take the brake lines (if they are different)
2) Parking brake cable (if it is different).
That is the minimum.
To do it right:
3) Master cylinder from the GTS. The GT and GTS have differnt line pressure in front and in rear, so neither master cylinder will be perfect for the GT, unless you upgrade the front brakes too.
4) DO you have ABS, if so, don't forget the ABS hardware.
A trip to your Toyota parts counter would reveal what parts are the same and what is different.
Scott
1 - 2 of 2 Posts
