I just took a ride with my bosses nefew in his 2004 GTO with a built engine. He has a t-78 mounted on the rear of his car, this thing is making 850 to the rear wheels and passing SMOG. Oh yes I,ll be getting one of these, no heat problems, no manifold problems, aannddd for mild apps no intercooler needed. Check it out at STSTURBO.COM
Well; I do understand all the arguments. Some based on facts & some on personal opinions. I can see the underhood systems are the way to go if you are a street racer, as I am not, I will be going with the RTS system. All I am interested in is when I,m in traffic and I want power for whatever reason is that it is there. As far as the system goes I did ride in the car and if I am not wrong the T-78 is not as some put it "a small turbo". I work in a shop where the lead tech builds race car engines for the circle tracks, and the owner owns a circle track race car, so there is not a lack of performance knowlege. But when my car is complete I will post numbers for all to see.
Looks like you made up your mind, good luck on this venture.
BTW have you seen the underside of your car? Scratches rock chips and all that goodies? Don't think your pipes going to get scratched up and cause a boost leak? When it rains all that water splashing on it what does it do to your setup?
Yes I understand about the road debris and the scratches so I am going to use header wrap, and the rain issue took me some time to figure out (not too much rain here in Vegas though) so I am going to run the air filter up thru a hole in the spare tire area, with another hole beside it with an air scoop to keep the rear hatch area pressurized with fresh air. My 2 Fosgate amps I,m sure wont mind the cooler air and with my 2 solo barics I wont be able hear any road noise.
Never understood this kinda setup either. I saw a twin turbo C6 with this setup. I admit it sounded nice as it took off, but didn't see the point of them being in the rear.
I've never been in a car with this type of setup, but I would imagine that (aside from all the issues with the turbo being inches from the surface of the road) the boost lag would be enormus. :ugh:
It is a decent alternative if you are too lazy or don't have enough money for a real turbo... or if you can hide it well enough to pass smog... but even basic knowledge of the physics of gasses will tell you it will never be as good as a conventional system.
Almost all of Porsche's cars are mid-engine...having a turbo in the rear of the car with a mid-engine is basically the same as having a front mounted turbo in a front-engine car.
