This year I'm able to do a rebuild of my engine (worn rings and low compression). Just got a job recently at the local Toyota dealership as an apprentice technician and my mentor is cool with helping me do this.
My budget is somewhat limited, so I can't do anything insane, but I'd like to upgrade at least something in there.
Here are my criteria:
I'm going to run at 79.5 mm bore, so that is set in stone.
I'd rather not do something that will require that I get a tune although I have an AEM FIC, because the local one has too much work on his hands right now and has never worked with AEM, just domestic. That will have to wait a while until I can like...go out of town.
I don't plan on exceeding the stock rev limiter.
I don't care if the car vibrates and firmly believe my passengers can pretty much just die in a fire if they have any complaints.
My fuel consumption must not exceed that of my BF's 2004 impala LS, which gets 19.6-25 mpg.
Parts upgrade budget is $400-550.
The three possibilities I'm looking at are:
Crower stage 1 N/A cams
Crower stage 2 N/A cams
WISECO 12.0:1 pistons in 79.5 bore, assuming the stock rods can handle it and the stock ECU can handle it (unless MWR has a base tune for that); I suspect the stock ECU cannot do it as it changes the volume of the cylinders in a way as well.
Other info about what I have (regarding the engine):
Short air intake, thrush welded muffler (yes, for real), DC Sports header
The stupid 4-speed automatic transmission
2006 "Pontiac" Vibe base FWD (so the DBW Corolla engine and ECU)
This is my daily driver
I'd like to run boost at some point, but that's a ways off anyway. I'm hoping to get at least a little tiny bit more kick because I'm sick of people just having to speed up a tiny bit to stop me passing on small highways because that shit is dangerous.
