1 - 3 of 3 Posts
ok guys heres the deal i just got my 1zz back from the engine rebuilders and im getting ready to install it this week my main question is ignition timing is it anything i have to worry about or should it be taken care of by the ecu
well...can you see the timing chain on the cam sprokets? there are markers on the chain to line everything up on initial build. if not, rotate engine to TDC and look at the marks on the cam sprokets...do a search, there are tons of threads for checking timing... if its all set right, then the stock ECU will do its job
1 - 3 of 3 Posts
