How do you remove the glove box on a 2002 Celica. I'm trying to get behind it to change the cabin filter but for the life of me I can't seem to figure it out. (doesn't help when I tried at night)
There should be 3-4 screws in the top of it when the box is open. There are also two 10mm bolts down in the corners in the wheel well. That should do it, unless they changed it from 00-02.
<A HREF="http://www.clonegts.com" TARGET=_blank> <IMG SRC="http://65.27.96.80/sig5.jpg" border=0> </A>
Click on sig to visit www.clonegts.com or see photos here and here.
HIN CHICAGO PICS HERE
How-to's
DRL Disable Redded out Taillights CAI Watershield Underdash Neons
Philips HIDs
Sponsored by Visual Dynamics
He just wants to change the cabin air filter. and all you have to for that is two unscrew the two thumbscrews inside the glove compartment (I think they turn forward), then the glove box will fall forward, and you pull out the air filter tray, right?
<IMG SRC="http://wsphotofews.excite.com/007/Mm/8M/PA/zI58156.jpg" border=0>
Thanks guys finally got it. The knobs were in there so tight from the factory I had to use an pair of pinchers wraped with a rag to break them free. Now they twist on and off without a problem.<IMG SRC="http://www.newcelica.org/ubb/smilies/cwm32.gif" border=0>
