I'm almost done dropping my tranny using the repair manual's directions, I can't seem to remove the drive shafts easily. Whats the best way to approach this? Do I really need any of the SST's?
How did you remove them? Did you undo the end bolt and the steering linkage and all that? I'm trying to shortcut that if I can and just pull themArcher2KGTS said:No, you shouldn't need any of the SSTs. The passenger side one pulled out quite easily.
The drivers side on the other hand, was a b.tch. I pried (SOFTLY) around the metal ring on the shaft right before the tranny to loosen it up. After doing that, you should be able to give it a couple good tugs and it should come out.
My hub bolt was a 30mm 12pt socket. Impact wrench for the win!SickCelica696 said:What size is the axle hub nut? Also how are you dropping the tie rod ends out? I tried the hammer but they don't budge downward
Already did. Grease everywhere.WHITEKNIGHT2000 said:whatever method you use to get the tie rod off, just dont f'up the rubber boot, ITS REALLY EASY TO RIP IT!!.
Thats what I figured. I have a 28mm and it was just a hair too small.Archer2KGTS said:My hub bolt was a 30mm 12pt socket. Impact wrench for the win!SickCelica696 said:What size is the axle hub nut? Also how are you dropping the tie rod ends out? I tried the hammer but they don't budge downward
The tie rod ends were a b.tch. That's why I was saying use a long ass pry bar. You sort of need to wedge it and get it on top of the bar. It will come off, it just takes He-Man to do it.
