1 - 10 of 10 Posts
not hard..if u have small hand u can squeeze ur hand with a open ended 10mm ratchet or something like that..the tool that have a circle on one end and the other end have like a "c" shape on it..must be a 10mm..
remove the two covers piece, one on each side, that cover up all the tail light socket.. can't miss it..in other word, on the driver side it's the cover that cover up ur jack..located right behind ur tail light, in the trunk..
find 3 black 10mm nuts and remove it..the first 2 u can see but the last one is hidden way up behind the plastic..so u gonna have to stick ur hand in there and feel around for it..
The last one isn't "way up there". It's like a couple mm under the corner, all can be reached with a socket or wrench if you want to
Just make sure not to cut the plastic!! < its not necesary and leaves your trunk looking like crap. If needed undo the back plastic peice on both side there sould be only a couple of plastic clips and use a 10mm to undo the grocery hooks also< all the hooks, clips and what not should all be in plain site, its really simple. Good luck.
1 - 10 of 10 Posts
