1 - 2 of 2 Posts
1995 Toyota Celica ST204R 2.2L FWD 5Sp MTM
I'm currently in the process of replacing the entire shaft. I understand (I think) that I need to remove the old bearing carrier from my old shaft and put it onto my new shaft. i have removed the C clip from the bearing, but I cannot for the life of me figure out how to remove the carrier. Any input would be amazing.
Can supply photos if need be.
This forum is used for 7th gen celicas. There are forums for the 6th gen which isnt this 1. Either way im sure its straight forward for replacement. Get the new part which im assuming you do not have yet.... look at it then replace it.
2000 GTS Turbo
1 - 2 of 2 Posts
