1 - 9 of 9 Posts
ok so i was going to remove my front bumper to paint the front emblem on my grill andddddddd i was loosening the 4 bolts on the top underneath the engine plastics and one snapped off while it was still in the threading. i got the other 3 bolts out but then i decided to just put the other 3 bolts in because i needed to figure out a way to get the rest of the bolt out of the threading. any ideas??
Trust me, I'm Asian.
They have tools that you can borrow from Autozone that will remove sheared bolts.
Sorry but I don't know the names of the tools.
12+ years daily driver
You need a screw/bolt extractor
yep. The craftsman set or a set of GrabIt bits will do just fine.
run the drill in reverse to drill down into the bolt. Once you make a decent pilot hole flip over the bit and while still in reverse start backing the bolt out of there.
Go ahead and order a new bolt so you can replace the bad one.
I would go for the craftsman set over the grabit. Go to sears, I think it's 29.99 or 39.99
damn i may as well just leave it how it is for now haha when it warms up this week i will keep trying to take it off and see if i run into anymore problems the only thing is im expecting to haha
Also a can of pb blaster would help..I would say a torch too but I don't think you would want to heat that area.
1 - 9 of 9 Posts
