I have a 2000 gts (automatic trans, blah!) anyway, I am going for some more performance mods and wanted to know if an s-afc would help out enough to make it worth its cost?
I have a trd cat back exhaust, cai, and soon to have a trial header installed. Can you guys help me out here and let me know if the safc would help, or if it wouldnt, what else could I invest in?
_Dave
[email protected]
S-afc put up alot of numbers when i first intalled it, it looks awesome and the uses of the true to engine tach, A/F ratio is practically impossible to count the uses. No negatives except for the fact that the actual a/f ratio will be readjusted by the ECU and there will be no gains, i don't believe it and no data has proven that, i actually plan to prove otherwise.
The S-afc for the 2zzge in my car is working great, I have a knock link and every time I lean it the knock link sensor senses the vibrations so that means is working...
S-afc is Good...
