is it safe to adjust the rear camber adjusters? i read in the toyota maintenance manual for our car and it says i should use torque of 55 ft. lbs. to tighten? how would i do that?
anybody that has done the rear camber adjusters..i would love to get some input from you...
thanks a lot....
ken
Hmm, I would use a torque wrench. Prices range from about $20 up to $150.
Adjusting the rear camber isn't really a big deal. The harder part is actually measuring what the new camber is. Also, keep in mind, when you change the rear camber the rear toe also changes significantly, you will need to reset that.
So, the conclusion? Alignment shop.
Scott
