1 - 11 of 11 Posts
Selling my Celica Audio Equipment, everything is in great condition considering i had all of this in a show car setup, so it hardly tampered with. Anyways on to the sale.....
JL AUDIO 10W7-3 10" 1,000 WATT / 500w RMS CAR SUBWOOFER
Features:
* 500 JL RMS watts (JL rated RMS Watts are about twice as efficient as the way most other brands rate the RMS watts)
* 1000 watts peak output
* 3 Ohm Impedance
* Extra thick Surrounds make the sub sound better, and have better sound quality
* W-Cone
* Radially Cross-Drilled Pole Piece
* Massive Forced-Air-Cooled Aluminum Alloy Frame
* Highly Linear, DMA-Optimized Motor System
* Huge Diameter, Progressive Roll Spider
* Co-Extruded Double Lead Wires
* Extra Long Voice Coil
* Proprietary Cone Attaching Method
* Reinforced Spider Attachment
* Size: 12"
* Very Very Thick Foam Woofer Surrounds
* Sealed Box Volume: 1.25 cu. ft.
* Ported Box Volume: 1.5 cu. ft.
* Sensitivity: 84.3 dB
* Top Mount Depth: 8"
* Cutout Diameter: 8 3/4"
$200 + Shipping
JL Audio 450/4 Car Stereo Amp Amplifier 4 Channel NR
Description:
Nice car amp ready to be used.
JL Audio 450/4 4-Channel system amplifier.
Features:
* 150 Watts x 2 + 75 Watts x 2
* 4-Channel
* Active crossover
* 24 db
* 48 Hz
* Subsonic Filter
* Channels 1-4 bass control, Filter Section, Input Section, and Speaker outputs
Great multi function amp sure to provide plenty of power for bass and to control your car's system.
$200 + Shipping
JL Audio 500/1 Amplifier
Additional Information about Jl Audio 500/1 Car Audio Amplifier
Product MPN
MPN: 500/1
Key Features
Amplifier Type: Mono Channel
Bridgable: Not Bridgable
RMS Power at 4 Ohms: 500 W x 1
RMS Power at 2 Ohms: 500 W x 1
Performance
Frequency Response: 5 Hz - 500 Hz
Signal to Noise Ratio: 95 dB
THD at Rated RMS Power: 0.05 %
Crossover / Equalizer
Bass Boost: With Bass Boost
Bass Boost Frequency: 15 Hz
Low - Pass Frequency: 40 Hz - 200 Hz
Other Features
Input Voltage: 11 volt
3 Way Ready: No
Dimensions
Width: 9.25 in.
Depth: 13.4 in.
Height: 2.36 in.
$250 + Shipping
1 - 11 of 11 Posts
