at about how many miles should this be replaced? also what might the cost be for the belt and the install?
With tool borrowing from AutoZone et al, or a medium breaker bar, it is an easy one person job from the top.I think you have to take the wheel off as well as the splash guard.
Thanks for that info I'll have to check that out.With tool borrowing from AutoZone et al, or a medium breaker bar, it is an easy one person job from the top.
yes, in the INSTALLS section:ugh:Thanks for that info I'll have to check that out.
Is there a DIY anywhere on here?
you talking about a really thin tool that just squeeks in there?With tool borrowing from AutoZone et al, or a medium breaker bar, it is an easy one person job from the top.
Pull towards front is correct, as I recall.toward forward, right?
