1 - 11 of 11 Posts
Hey guys, i have a few random parts for sale. All prices do not include shipping. If you give me your zip ill gladly quote it for you.
All prices are also OBO!
2ZZ (C60) Shifter linkage $30
Clutch Slave cylinder and line $15
The cylinder is less than a year old. I think the line was bent during removal, but it is not broken.
1ZZ Engine Cover $25
If you want this painted or something i can do that for you. I may also be able to have some sharpie art done for you...
2ZZ INCOMPLETE Wiring Harness $5-50
This harness came off a 2zz i swapped into my car but it was cut at the relay harness so i couldnt use it. If someone wants the whole harness ill sell it, but if you only need a couple connectors ill clip them with as much wire as i can get and part it out. This includes the VVTi-L connectors needed for a GT harness.
I also have a LOT of 2ZZ engine parts so if youre looking for something specific let me know. Im going to try to post that in the next week or two.
Thanks!
Sorry guys, vacation made this hectic for me.
Shifter Linkage is sold
Slave cylinder is no longer available (mine just broke)
I will be adding spacers, studs and possibly some other goodies next week!
Sent from my LGLS991 using Tapatalk
Hey guys, i have a couple more misc things to add!
A set of hub centric 5mm spacers, 15mm spacers, and 10 extended studs. I never used the studs or 15mm Spacers but the previous owner did. The 5mm spacers were on for about 10,000 miles and then i got new rims.
Looking $45+ shipping for the full set.
1ZZ TRD ignition cover
Ive never seen another like it so im guessing it was a custom build. Bolts right on, no hassle.
$25 + shipping
2.5 inch intake charge pipe
Polished and looks nice but it does have a few blemishes from storage. Includes a 2.5 in Vibrant hose coupling. Mandrel bent Aluminum, and i believe it is a 3 inch bend radius but i would have to double check that.
$50 + shipping
As before all parts are OBO so feel free to make an offer.
Supahfly i fortunately did not have to remove the linkage, it came with my new engine and trans. Im sure theres some posts on here somewhere with a how-to guide.
Shifter Linkage - sold
Slave Cylinder - unavailable
Wheel Spacers - sold
Vvti cover - pending
TRD cover - pending
Intake Pipe - $55 shipped
Harness connectors - $5-40 shipped
· Let's hit the track!
Cable replacement
I just did that cable job, and did it right. All brackets were reinstalled correctly as per the factory. It's not as bad as I thought it was going to be. The number one hint is to remove the two tiny rubber retainers at the top of the sealing gasket/plate assembly under the heater box when re-installing that plate. Those two bolts retaining are the hardest part of going back together. 2nd is the cable retaining bracket under the tunnel right in front of that plate. It's all very tight in there. Patience is key. Feel free to PM me if you'd like. Is there already a cable replacement guide on this site?
1 - 11 of 11 Posts
